Navigator III & Full Map Install Problem?
gsbiker
Devon & Cornwall
Well I took a leap of faith and purchased a lifetime map updates for my Navigator III. During install/download it asked what map I wanted after telling me there was not enough room on my device for the full UK + European maps? I have since chose UK + Ireland but my devise should be able to install full European maps surely? What can I do?
Why do you think your device "should" be able to install full European maps? Things move on all the time. Your NavIII is really just an obsolete Garmin 2820. Each iteration of City Navigator is larger than the previous one so that the latest version is now in excess of 2 GB. The internal memory in a 2820 isn't large enough to store all that.
What can you do...? Download the full update to your PC and then install the maps which you require into your GPS unit as you need them.
To do that effectively you'll either need to delete your primary mapping file or replace it with a custom made one.
Start by installing City Navigator to your PC only which is an option on the download. If you already have this then don't bother with this step.
Method 1 (effectively delete primary mapping) - Then, from Mapsourec, write a new one tile (NORDSEE 1, being a chunk of North Sea without any roads, is only 5MB) gmapprom.img file to the internal storage of your GPS, this will overwrite your pre-installed mapping and leave the vast majority of your memory free. I believe that the 2820 has a mass storage option so this is relatively easy to do when compared to the SP 2720. You can then highlight the map tiles you do want and send these to your GPS by using send to device from within Mapsource. Every time you do this it will overwrite your mapping.
I'm not sure if the 2820 can get by without the presence of a gmapprom.img primary mapping file, you might want to try deleting it all together though it might throw an error on boot when it can't find one. Replacing it with a smaller NORDSEE 1 tile is probably the best approach.
Method 2 (replace primary mapping) - A better and more permanent solution is to write the tiles you want to a USB stick form Mapsource using 'send to device' and rename the resulting file from gmapsupp.img to gmapprom.img. Then transfer that to your GPS overwriting the existing file of the same name.
The geographical regional options offered on the map update download didn't offer the right areas for me so I used the method in the paragraph above. Somewhat more complicated with my 2720 as there's no mass storage mode, I needed to get involved with command line stuff and some Garmin VoDo.
Be warned that mapping transfers between PC and your GPS can take hours. You obviously need to have the mapping in Mapsourec unlocked for your specific Garmin unit, just because it works in Mapsource doesn't mean the transferred maps will work on your GPS
Delete all of the language files off the device that you don't need, this gave me enough space for the update, world map & moroc topo - "settings \ general \ language \ voice language" then select the ones you will never use and delete one by one - :thumb
I did wonder how to do this as there must be unused data just sitting on the devise. Where are you accessing "settings \ general \ language \ voice language"? Cause I can't delete them from the devise.
From the main screen as seen once the device is on, then "settings \ general \ language \ voice language" then select the unused language which then gives you the option to either cancel, delete or OK.
Thats great, now deleted all those foreign languages. Device seems faster or is that just me?
Have another related problem. Just spent couple hours downloading maps again just to the computer. No sooner does it finish downloading it comes up with a problem with the application. I sent an error report but thats it game over! Starting all over again now but I'm not confident it will install! Ive already installed the UK+Ireland maps on PC + devise but trying again to install Full Europe maps on PC alone but having problems!
