Need some help Armaxis jacket
retry
london
Hello,
recently i bought armaxis jacket with armaxion pants.. all good except 1 thing - neck collar.. how to wear it ? should i put it inside the helmet or keep it outside? tried both ways Very uncomfortable, if you need to turn your head to check blind spot it will scratch your neck .. every time ...
Hello,
I use my collar during cold month every time and it is perfectly fine with me. Works a treat.
I've got a Navigator Jacket, same collar. Use it all the time brilliant. I do the jacket up, then the collar and then put the Helmet on, the collar kind of sticks inside the rear of the helmet and the chin strap does up over the front bit. No issues with turning my head, keeps drafts a wet out really well. Needs to be quite tight, which is difficult because the armour stops the arms going up high enough to fasten, so I kind of push the collar with my right arm rearwards to get it snug :)
Hello,
Hi EVskij, I have the same gear. Only used the collar in really bad weather. I put the collar on get it comfortable i.e. No Velcro catching anywhere then just pull my lid on after. It seems to find its own place under the lid and I have no trouble with it.
Clive
Clive
Yeah in the summer it is s bit of overkill. Likewise jacket done up fully, helmet on, gloves, ride on..... easy! What is all the fuss about?
I have navigator and flexius jackets both use identical collars.
thank you for reply gents, obviously some people have some dont.. i guess it depends on position of riding, on type of helmet etc.. thank you ! will be buying rukka 4 air for summer period :D
