alecmuffett
I picked up my 12GS from SPC on friday afternoon (here's a tip: pick up new bikes weekdays if at all possible; I was the only one that afternoon, versus the chaos that was apparently due on saturday) - and I have put 320mi on it since then.
I am "being a good boy" and running it in by the book, having talked some things over with Tim at SPC and finding they were suggesting pretty sensible things - so the mileage to-date has 98% been below 4000RPM, never above 4500 except for the occasional throttle blip when changing gear, etc.
Oil checked every major park-up. So far, so boring. First service due in 300ish miles.
The only real worries (I suppose) are the occasional "searing plastic/oil" smell when riding - I have tried checking for oil leaks and found nothing to-date.
One thing I am definitely noticing, though, is a definite "clonk" when clutching-declutching in first, and likewise (obviously) changing to/from second. Also there tends to be a bit of a gentle jolt-forwards when first releasing the clutch after changing into neutral from out of first.
Does this square with people as "normal gear-box running-in", or is it a bit off?
