New Gs 1150 Exhaust
MIKE R
Burnley
I am considering replacing my standard 1150 exhaust with a road legal Remus system. I believe this will give me more mid range and they sound rather nice. I believe the collector box has to go and I have been advised to fit a BB chip. Anyone out there got any info? Would a K&N filter be a sound investment? Could I fit it myself, or should I leave it to the experts? Any comments greatly appreciated.
Mike R
Remus can and BB chip...
Mike,
The fitting of the Remus can definitely frees up more mid range and gives improved throttle response and the BBpower chip is well worth it too. The fitting of the can, Y-piece and chip are well within the capabilites of anyone who can use a spanner and a screwdriver.
I have fitted both and in the GS Misc section I have posted a document that tells you how to fit the power chip.
When you remove the Catalytic converter you will need a large ring spanner, I think it is 22mm, to remove the lambda sensor which is torqued up pretty high. You need to trace back the sensor wire to underneath the tank and disconnect. You can then remove the cat and get it onto a bench to get some leverage on the sensor nut.
The other thing is that you will experience some extra vibration with the Remus can. I tried to isolate mine from the subframe as much as possible with extra washers and a home made rubber isolation spacer, which seems to have done the trick.
I haven't fitted a K&N filter but that is on my list too.
Best of luck
Mike
Thanks for the info, but after talkiing to others who have done the mod, I think I will stay with the standard system for a while and save a few quid.
Cheers.
MIKE R:beer:
Remus can / Touratech Alu Cases
Has anybody experience with the Remus can in combination with
Touretech's special ZEGA-cases? Does the left part of the rack still
fit around the can?
Zwerver
I started a thread about the special panniers and a Remus can, a while back. There not desined to fit, however, it can be done. Dave Turnock has done it and I will probably follow suit.
Have a look at the link below it'll take you to the thread and Dave's advice about the mods required to fit.
http://www.gsclubuk.net/forums/showthread.php?threadid=187
Simon T:beerjug:
HI IHAVE A REMUS GENESIS END CAN FOR SALE ROAD LEGAL DONE 100 MLS THE WIFE HAS TINNITUS SO IT MADE IT WORSE {EARS} ANYWAY SELLING NOW BOXED 150 QUID +p&p
Being a complete dunce when it comes to the workings of the catalytic converter, can anyone explain why the the removal of the cat has a significant effect on the power of the bike? especially as I've read that there should be no reduction of power at all.
Makes me wonder if the cat versions of the Remus systems are any less powerful than the non-cat versions.
cheers
Luga
I think removing the cat makes the exhaust less restricted and allows the engine to "breath" easier thus making it rev freeier(spelling?). Although I have not had this done on the GS I have had my TVR de-catted and run on a rolling road before and after the gain in BHP was only about 3 or 4 which is not huge when the max power output was 270bhp. But the engine does rev much much easier making the power more usable.
Andy
Remus Cans
I have just ordered a Remus can and Y pipe for my GS . I note that the sensor on the cat needs to be changed .
Where does the wire go as I have had a quick look but canot see where the wire goes ? Also do I disconnect the wire only to change the pipe or permently ?
I have a K.N . filter as well does this all help remove the stuters at 2800-3000 revs. KEV.
Kevin,
You don't need to change the sensor, just remove it from the cat (it unscrews) and fit it into the hole in the "Y" piece. In combination with a K&N, you should certainly not have any surging in future.
I have the same set up but Sebring and have changed the intake tubes for those from an 1100S and have a Superchip installed. The difference in pick up/drive is remarkable. Smooth, progressive and rapid are the best way to describe it, all the way from just above tickover and even in 4th, 5th and "E" gears.
I don't know if this useful or not but ....
I replaced the cat with a touratech Y piece but kept the original silencer.
Did bugger all with the sensor. Simply put the lambda thingy back in. I've got an increase in mid range, a significant improvement in fuel consumption (about 5mpg) and a slightly nicer exhaust note and weight saving of 3 kg or so.
The Y piece alone is worth the change in my view.
It seems to me that the improvements are due to the restriction the cat places on the exhaust, but maybe that's too simplistic.
Mike R. and Kevin:
The main performance gain comes from replacing the catalytic converter with the Y-piece. The lamda sensor simply unscrews from the cat and is replaced/screwed into the new Y-piece. The engine management system adjusts itself to compensate for the change in exhaust gases.
There are a few extra horses to be gained from fitting a different end can, particular if you go for a race can. One of the main and obvious savings though is in the weight difference between old and new systems.
Performance really takes a hike when you add a performance chip. The BBChip for the Sebring/Remus systems is an excellent bit of kit allowing adjustments for about 6 different settings and compensation for different fuel octane ratings (for RTW trips) but it's expensive (about £280).
All in, a Remus Y-piece, Titanium can, and BBChip, will set you back nearly £800 (fitting it yourself). Obviously there are a lot of second hand bargains out there and the alloy race can is a cheaper alternative.
I've fitted a Laser Pro D'Or System with Superchip and if you buy direct from the suppliers and fit yourself you should get it all-in for about £550. It's a slightly more aggressive system than the Remus, higher pitched whine when you accelerate, and very very responsive on the throttle, giving marginally better performance. Neither set-up should lose you fuel consumption even though the bike runs richer.
Obviously, a cheap starting point would be fitting a Sebring Y-piece from Bracken for £150 and keeping the standard can. You'll be well pleased with the result . . . but be warned, you'll want to go the whole hog.
I was a skeptic about the need for it, but now I'm a convert and zealot. It totally transforms the GS into a much better bike.
Simon E.
Remus Can
Thanks for the replys . I have spoken to JB Racing today and should receive new system this week . should give me time to fit it this weekend , in time for Princetown . I will post update after trying out the system only hope they get it to me in time .
Can the sensor be removed without disconnecting the wire connected to it ????????
Kev.
Yes, you can remove the sensor without disconnecting it. You will need a 22mm spanner to do the job, and it is easier to do it before you remove the collector box.
Bob Southgate
Remus Exhaust (Fitted )
Received Y pipe and Exhaust this morning , Fitted complete system in about an hour . The hardest part was the little cover at the bottom of the can . The sensor was tight but no that difficult to remove .
Well just come back from first test run . RESULT much better a lot smoother the power band seems a lot smoother through the range also at 2800-3000 revs there is very little lump in the engine at 30 mph (speed camera speed ) much better . The bike seems a little faster but that could just be the sound and yes it now sounds like a motorbike !!!!!!!!!
See you all at P/town
Kev.
Get it chipped Kevin and fit a K&N filter, then you'll really notice the difference.
Simon E.
I plan to fit a Remus alu race can, y piece and K/N filter. can this be done without fitting a chip?(until i can afford one.):cool:
Simon .E
Thanks yes I have fitted a KN filter at the same time , as yet not a chip . I will give the new system a try first then consider a chip also the bank balence needs to be replaced a little first
Thanks KEV
