New Injectors
Globetrotter
NW, England
Can anyone point me in the right direction for new injectors on the gsa1250 please?
Been looking and I'm no wiser so thought I'd ask a fellow :ukgser
Mixture preparation adaptation bank 1 and 2 need assistance.
Do you have a permanent fault code? Running issues ??
This is a common stored fault found if you're reading fault codes using a reader. If you have nothing on your dash and no issues, it can be ignored.
Yeah, there's an engine warning light but this could solely be down to the exhaust flap, not sure until I get the Servo Buddy on Thursday and try the fuel cleaner tomorrow as theoneandonly mentioned, the bike hasn't had this under my ownership in 12 months so I'm sure this'll help the sluggish performance to be fair... Thanks a lot
Engine warning light was the servo; Servo Buddy was the fix.
Early days, but the fuel additives has definitely made a difference after a quick 125 mile ride this morning 👍
Warm it up then thrash it under load, it will burn off any carbon deposits and a maxed out injector pulse should give them a good flush through to help restore the spray pattern.
Cheers Adam, that was similar to my logic this morning with quick-fire bursts here and there, definitely helped.
from what i have found over the years Forte make the best injector cleaner ,its not cheep i think about 18 quid a bottle and note petrol and derv cleaner is different stuff
