New rear brake disc needed ...
Bobbin-Man
Chester
I need to renew my rear brake disc, anyone know what the thickness of a new one is ... and what the minimum wear thickness is?
IIRC 5mm new and 4.5mm service limit.
I used Wemoto for disc and pads when I did mine.
Steptoe does them I believe
Sent from my SM-G920F using Tapatalk
I may as well be the one to mention it as someone will need to eventually :D
It is advantageous to heat the retaining bolts up to release the loctite
type stuff holding the bolts and, ensure the tool you use is a very good fit into the bolt head as it is quite easy to
strip it.
Another bit of good advice is to obtain new bolts before you do the job.
All this is from experience :thumb2
