AUTOSWITCH
MODERATOR'S EDIT....
This post was moved and split from Rob's Autoswitch thread as it was considered a blatant Hijack
More information coming...I've just spoken to Paul and we have a solution coming up, but for the time being, here it is.
End of edit.
_________________________________________
We will have stocks of the Autoswitch from Sept 3rd priced at £12.99.
This 5NB version of the Autoswitch is designed to suit all BMW models from 1995 on.
It takes a negative (ground) pulse from your turn signal cancel button. You just hold the button for more than 0.8 second to switch your auxiliary light relay on or off.
When you want to cancel a turn signal you do it normally, by a quick tap on the button, usually no more than half a second.
In addition there is also a 5N2 version.
The 5N2 version is to be used as a SECOND controller for a second use. Activates a second relay without affecting the first one. This model takes 2 quick pulses BEFORE the 1.2-10.0 second release window of the normal 5NB.
WIRING DIAGRAM ATTACHED
End of edit.
