stevebrooker58
Hi guys,
Have had an issue with my R1150GS 2003 model.
The issue started with the bike cutting out at speed and stalling at junctions , suggested by forum members to clean the connector under tank , did this and seemed to get better , but the faults returned stalling at junctions when slowing down , but would start again and all would be ok for a bit until next junction.
So I decided to clean the BBS and flush the hole through , this done tried to balance the throttle bodies but couldn’t get it to tick over and the BBS’s were only about a quarter of a turn out . So then I changed the o rings on the BBS’s and the vacuum take off bungs , checked the stick coils using a meter they were outside the tolerance so replaced them as well . Still no joy the bike ticks over gets slower and slower then when you twist the throttle it pops and bangs and either cuts out or ticks over , so checked all breathers on the tank and found one blocked by a couple of dead bugs , I blew up it towards the tank could hear air entering the tank and returning out .
So I gave it a good look over and there appears to be petrol staining on the crankcase underneath where the fuel pipes disappear towards the fuel meter .
Any ideas would be welcome , thanks in advance .
Steve
Steve
