£100 postage available at extra cost
Brand new all the internal bags and booklet still sealed, outer box only opened for photograph.
This transparent, fully functional model consists of 200 parts that can be screwed together, has a switchable 5-speed gearbox and working engine components, and you can even listen to the boxer engine via an integrated sound module.
In addition, the extremely detailed kit comes with a 120-page, high-quality manual that contains a vast amount of knowledge about the history of BMW motorcycles, the R90S and the successful concept of the boxer engine.The manual also contains detailed and easy-to-understand assembly instructions. This means that assembly can be carried out without any prior knowledge.
Specifications:
Transparent, functional model
Two-cylinder engine of the legendary BMW R90S
Moving crankshaft, piston, cylinder and 5-speed switchable transmission
Sparks are simulated with LEDs
Original engine sound thanks to integrated sound module
Components are easy to stick and screw together - without any adhesive
Step-by-step construction manual
Width cylinder to cylinder 34cm
With pedestal stand
Requires 3x AA batteries (not included)
Model dimensions: approx. 160 mm wide x 355 mm high x 465 mm deep
Video of the built kit in action -
Unwanted gift, ideally collection from Cornwall.
Specifications:
With pedestal stand
