A mish mash Hodge Podge of a Lovely wee scruffy Loveable Pile of Pooh! But it's a cracker
So the story so far delivered and abandoned I Did a once over inc comp check and pronounced it do~able
So fixed all the ancilliaries overhauled the alternator and starter and fitted new leads
Stripped carbs, blew out and cleaned all crud out of fuelways and fitted new diapraghms and floats (and set them), also did needles and pilot screw o rings and fitted a feck off big fuel filter to stop crud from tank.
Jets didn't look too worn when I tried the needles in them but something isn't right
She starts and Idles fine but when you rev up and release the cables are returning okay and the slides seem to be dropping okay
SO why won't she go back to tickover??? it remains at a very fast idle for a minute before it drops back
Intake tubes are fine and sealed and I can't detect an air leak and as I've said the compression check was good and fairly balanced but it's running like a bag of pooh again?
Timing is spot on and the valve clearances done too, although someone has done the zero clearance on one side to stop the rocker arms rattling off the posts
So before I launch into another whole strip and dismantle fest
Has anyone any useful and sensible suggestions which would be relevent to this wee motorcycle and it's present predicament?
