Rod-R1200GS
I recently went off roading in rather deep mud on my 2007 (May) BMW R1200GS, during my ride a branch/twig caught on something near the throttle cable, under the handlebars. Following this, the bike seemed to run on 1 cylinder then die.
Then trying to get it to run, the throttle had no impact on the revs of the bike, it stayed at idle. So I used my fingers to twist the butterfly flap and do the throttle manually via the left-hand cylinder. That's when I noticed that the plastic throttle guide had snapped. I did this manual effort to get me out of the mud, I was panicking slightly but I do remember it running only one cylinder...
Since coming home, I've taken the bike apart in efforts to ascertain why the bike no longer runs on two cylinders. I've fixed the plastic throttle guide - But still nothing. It has good compression, 155 psi both sides however when I take my vaccuum guages to the throttle bodies, the cylinder which is not firing has no vacuum. Based on this, I thought to check the valves or piston rings. I've done the valve clearances, although to be fair they weren't really out and I've ensured that there is no valve damage, the piston rings are also good.
I bought a GS-911 scanner and there is no fault codes, annoyingly! I've also synced the throttle bodies via the GS-911 scanner.
I'm really stuck, any advice would be SO helpful!!
. If you operated the butterflies yourself, then presumably that's singular, since you could only operate one and (somehow) ride out of the mud? That would mean only one cylinder getting the juice.... No?
