One cylinder only? from 60% throttle upwards
  • Thread starter Thread starter IanC
IanC
Currently in Chile, and my 1200GSA has started misbehaving this morning after over 22,000 trouble-free miles on this trip.
Runs fine up to about 60% throttle, then sounds like it's running on one cylinder. Doesn't appear to be engine-speed or load related, just throttle position, although this varies slightly from perhaps 55% to 70%.
Weird thing is I dropped it in some gravel yesterday, and caught the LH throttle body with my boot and pulled it out of the rubber intake manifold (only at the cylinder side, not airbox). I didn't notice at first and actually fired the bike up, but something was very obviously wrong! Thankfully I managed to get it back in with a little spit, and it seemed to be running fine afterwards, for the rest of the day, 4.5 hours. Problem only manifested this morning - I had thought it might be altitude of 15,000ft, -3C this morning, or dodgy petrol, but I've now descended to half that and put some good 97-octane gas in (after nearly empty) but still the same. Besides it has been fine at similar altitudes so far, if down about 1/3 on power. It did take a little starting this morning, but this was probably the temp/altitude.
The throtle position sensor and injector leads are obviously OK as the bike won't run without them (or one cylinder only), so the only one that could have been damaged is the one on top, and I'm not sure what this is? I had thought that maybe the intake manifold was not sealing properly and sucking in air, but it looks fine and I would have expected there to be problems at LOW throttle rather than high if this was the problem, due to more vacuum.
Or maybe it's just a coincidence - does this sound like dodgy spark plugs? After all the bike seemed to be running OK for a while.
The bike is rideable, but I'm about 900 miles from nearest BMW dealer in Santiago (who has a not-good reputation anyway), so would like to try and sort the problem myself.
Sounds similat to mine last summer.
It came on pretty quick. From nothing to very conscious misfire in about 10 miles.
Coil was changed and still missed slightly, so they changed spark plugs and fixed it perfect.
They already had about 4000miles on them at the time.
Some other posts about dodgy plugs, so worth trying as a first step.
Only other thing I can think of is an air leak..
Hi Ian, could it be something as simple as needing the throttle reset... the same process you have to go through after disconnecting the battery?
I might be a million miles off the mark, but is it worth disconnecting and reconnecting the battery then going through the reset process? If it works all well and good, if not you've only wasted 5-10 minutes...
Only mention it as one of the other guys had a similar problem here today.
Ian,
if it's more "throttle" related rather than "revs", then it could be something stopping the LHS butterfly valve fully opening? Especially as the whole body has recently moved. I don't believe in coincidences;)
Check the routing of the cable. It could be snagged, or the cam damaged.
You might have to take the body off and check for full movement.
Good luck...............................
Got it sorted
Thanks all for suggestions.
I decided to put in a spare set of plugs, and when removing the plastic snap-on plug cover the problem was obvious - the lead had pulled out of the coil on the LH pot. It ran surprisingly well on the secondary plug only. Maybe the plug had not fully parted company initially, and due to the extreme cold the cable had contracted overnight causing the problem not to appear till the morning?
