Open question for PARA
  • Thread starter Thread starter christianburgess
christianburgess
Para
I have asked your opinion in the past and find i can (usually) understand the answer (and that i often can't from other contributors!) so here goes:
1. should i fit a remus?
2.should i fit the y piece?
3.WHICH remus?
This is on my new ADV which i find has an objectionable whiny sound particularly at lower speeds in higher gears......so my problem with the OE is sound rather than performance (so i wonder if a remus box on to OE y piece might be ok?)
I am asking as i believe you have carried out this mod.....
ALSO and this is a question for anyone ..... does the CORBIN seat for the ADV make it even higher off the ground....i am assuming it must because it is wider.....i loved the Corbin on my 1100 but i could have it at the low setting which was fine.....i fear on an ADV you'd need to be 7ft tall and i'm only 6.....
i realise we are in well ploughed ground here but i cannot QUITE find the definitive answer by chasing old threads.........AHAH the definitive answer......i anticipate a fair dose of mockery.....well deserved
Fitting a y piece and a revolution seems to have made my front end very light...it keeps pointing upwards ;)
:D
