rovert57 Well-known member UKGSer Subscriber Joined Aug 23, 2014 Messages 3,546 Reaction score 1,251 Location WIRRAL Dec 22, 2016 #1 hi all I have an optimate charger and the fuse has gone in the connector lead that stays attached to the battery, what amp fuse is it .
ghost-rider Well-known member UKGSer Subscriber Joined Nov 13, 2012 Messages 1,176 Reaction score 4 Location Birmingham Dec 22, 2016 #2 hav a look and see for yourself
Bryn Well-known member Moderator Moderator Joined Sep 20, 2003 Messages 14,040 Reaction score 448 Location South Leicestershire Dec 22, 2016 #3 2 amp should do it
rovert57 Well-known member UKGSer Subscriber Joined Aug 23, 2014 Messages 3,546 Reaction score 1,251 Location WIRRAL Dec 22, 2016 #4 no indication on the fuse itself 2 amp seems very low
bigtwin Active member UKGSer Subscriber Joined Feb 25, 2012 Messages 385 Reaction score 46 Location Derby Dec 22, 2016 #5 Typical charging currents are usually about 10% of battery capacity so 2A seems about right. What's the worst that can happen?
rovert57 Well-known member UKGSer Subscriber Joined Aug 23, 2014 Messages 3,546 Reaction score 1,251 Location WIRRAL Dec 22, 2016 #6 rang optimate they bloke says up to 5 it's 7.5 amp after that 15 amp
JJH Well-known member UKGSer Subscriber Joined Jan 17, 2009 Messages 11,388 Reaction score 1,625 Location Co. Meath Irish Rep. Dec 22, 2016 #7 And the one after that is 20 amp. What's up till 5? Is that pm? I would say 2 amp but no more than 5 under any circumstances. JJH
DC Registered user Joined Mar 29, 2014 Messages 4,185 Reaction score 36 Dec 22, 2016 #8 is it a blade type fuse ? they are coloured coded http://www.healey6.com/Technical/Fuses.pdf
Rugged Path The Honourable. UKGSer Subscriber Joined Jul 23, 2004 Messages 2,370 Reaction score 123 Location Wybunbury, Cheshire East, England, EU Dec 22, 2016 #9 7.5amp is what they normally come with. Sent from my iPad using Tapatalk
Chicken Active member UKGSer Subscriber Joined Oct 21, 2015 Messages 395 Reaction score 42 Location Cambridge Dec 22, 2016 #10 Mine was supplied with 15 Amp
wessie Well-known member UKGSer Subscriber Joined Jan 8, 2002 Messages 19,670 Reaction score 7,780 Location Welshpool Dec 22, 2016 #11 http://accumate.co.uk/OptiMate 4 CanBus Edition Instructions.pdf 15A - see "BATTERY CONNECTIONS" section
rovert57 Well-known member UKGSer Subscriber Joined Aug 23, 2014 Messages 3,546 Reaction score 1,251 Location WIRRAL Dec 23, 2016 #12 Up to optimate series 5 Sent from my SM-G357FZ using Tapatalk
rovert57 Well-known member UKGSer Subscriber Joined Aug 23, 2014 Messages 3,546 Reaction score 1,251 Location WIRRAL Dec 29, 2016 #13 went out to connect the charger up and the 10 amp fuse had blown , nothing has been connected to the lead ,bike has not been used . very puzzling
DC Registered user Joined Mar 29, 2014 Messages 4,185 Reaction score 36 Dec 29, 2016 #14 rover .do you have a lot of accessories on the bike ? just thinking you might be overloading the can bus system and this is causing the blows when you plug something extra in
rovert57 Well-known member UKGSer Subscriber Joined Aug 23, 2014 Messages 3,546 Reaction score 1,251 Location WIRRAL Dec 29, 2016 #15 no just what the bike came with its a 2011 gsa with the usual aux lights grips etc . the charger leads are straight to the battery .
MikeO Well-known member UKGSer Subscriber Joined May 31, 2002 Messages 12,409 Reaction score 982 Location Dereham, Norfolk, today... Dec 29, 2016 #16 rovert57 said: no just what the bike came with its a 2011 gsa with the usual aux lights grips etc . the charger leads are straight to the battery . Click to expand... Have you pinched the cable? Easily done in a small workspace...
rovert57 Well-known member UKGSer Subscriber Joined Aug 23, 2014 Messages 3,546 Reaction score 1,251 Location WIRRAL Dec 29, 2016 #17 Wad thinking that but cannot see any damage Sent from my SM-G357FZ using Tapatalk
