overfilled it with oil...............
  • Thread starter Thread starter Terzikat
Terzikat
OK I'll put my hand up, I am a tit:blast
I topped up the oil on my 12GSA and put too much in:(
It's only a bit too much but the whole of the sight glass is covered by oil when the bike is upright on the centre stand
If I tip the bike a fraction over to the right the oil immediately drops down into sight and within the red circle.
Is this something I need to worry about on a GS12? I know that on some bikes the oil level is critical and over filling can lead to blown oil seals.
Therefore should I:
a) drop the sump plug and drain some out
b) ignore it..........it will use that much oil in a week or so
c) stop being so anal its only a bike
answers on a post card please:nenau
Take the N/S rocker cover off ...
... and lean it over, once sufficient has dribbled out, put the cover back on :nenau
Don't worry about it, it won't do any harm. On the 1150 it blows into the airbox if over filled alot. It will burn it of after a few miles :thumb2
You can lean the bike over and pull some oil out of the filler with a syringe.
Option b).
Whenever my bike has been to the BMW dealer for servicing it always comes back slightly overfilled - ie no sight line visible until the bike is tilted slightly to the right.
Option b).
Yep, mine's always like that just after a service.
so option c:)
park it on its side stand over a few days use. Oil will apparently drain into LH cylinder when stationary and burn off on start up.
Option b).
Mine was the same when I picked mine up & I thought it was overfilled.
I could smell a burning odour for a few hundred miles & thought it may have been the valet preperation work they did on the engine but it could have been an oil smell.
It's fine now. Smell gone & oil is a few mm below the top of the sight glass.
Shouldnt worry about it but I want to know how you tilt the bike over to the right whilst still being able to see the sight glass.......:eek:
Same experience as Yoda, mine has been overfilled by BWM after a service and no harm done.
Ride and ignore it.
