Sold oxford magnetic tank bag
shifty
lytham st annes
oxford lifetime luggage magnetic tank bag. this is a great multifunction system, you have the magnetic base with map pocket (there is a small piece of the transparent plastic missing from the map pocket sleeve, see where i am pointing in pics, never used as just a map pocket so never bothered me ) then you have the smaller of the two tank bags that zips to the base, then the larger bag that zips to the top of that , you can use one or the other or both together, the larger bag also has ruck straps so can be used as a ruck sack too,the larger bag has side compartments aswell, both bags have map pockets , there is a small bag attached to the larger bag that can also be zipped off and has a belt attached so can be used as a bum bag,, comes with a waterproof over cover aswell,, all zips work fine ,
