THE DOCTOR
Just bought a great set of 'ARD Cases' from redcap & I'm very happy with them.
Well, initially I was happy until I mounted them, put padlocks on the latches & was greeted with a cacophony of clanging that would put a campanologist to shame every time I moved the bike.
I came up with this...
I use a non-hex headed bolt with a compression nut.
This means the nut is a tight fit when assembling so will not work loose.
When fitting the nut you need an allen key inserted into the tail of the bolt to stop the bolt spinning.
This means any opportunist thief attemping to tackle this bolt would need the correct sized spanner & allen key (a socket would be no good 'cos you need to hold the bolt tail with the allen key)
A padlock can be easily opened with one swift blow.
What d'yer think?
I can supply 4 bolts 4 nuts & 8 nylon spacers or 2 bolts 2 nuts & 4 nylon spaces if you have a hinged lid.
You'd need to supply your own spanner & allen key. (I'll supply details of correct sizes.)
OK, you've got to carry a small spanner & allen key in your pocket but if like me that's not a problem PM me if you're interested.
What d'yer think?
