Part Number Needed Please
Andy Hird
Scarborough,England
Hi Folks
I have a 2006 1200 Adventure and I have lost the threaded bush from the windscreen main turnscrew. I've had a look on realoem.com and it list the part as a domed head nut, which it isn't the actual part used on the bike is a threaded bush about 7mm long with a round on one side of about 12mm dia. on the bush part it has two machined flats that fit inside the mounting bracket to stop it turning when you fasten the screw. I need a part number fro this threaded bush. Can any body help ??
Andy
No Part Number Description Qty Each
01 46637703196 windshield BUY 1 $299.23
02 46637694397 clamping bolt BUY 2 $7.47
03 46637676997 exterior bush BUY 2 $5.74
04 46637676996 bush BUY 2 $5.74
05 46637694393 covering left BUY 1 $3.06
05 46637694394 covering right BUY 1 $3.06
06 46637694398 plastic washer (DI=17) BUY 2 $2.22
07 07119924324 cap nut, chrome (M6) BUY 2 $1.80
08 46637694709 windshield bracket, left BUY 1 $8.50
08 46637694710 windshield bracket, right BUY 1 $8.50
09 06327657949 fillister head screw (M5X16MK) BUY 2 $0.96
09 46627684546 fillister head screw (M5X18) BUY 2 $1.93
10 46612308594 flat washer - Up to 10/2007 BUY 2 $0.78
10 46637670459 bush (6X6) - Up to 10/2007 BUY 2 $1.87
10 46637709435 grommet - 10/2007 and above BUY 2 $1.93
11 46637670459 bush (6X6) - Up to 10/2007 BUY 4 $1.87
11 46637709434 collar bush - 10/2007 and above BUY 2 $1.87
12 07129900645 hex nut (M5 SW) BUY 2 $1.29
13 46637694395 support BUY 1 $229.08
14 46627692608 fillister head screw (M5X20) BUY 2 $1.93
15 52532308647 nut (M5) NA 4
16 46637686286 flanged cap screw (5X16) BUY 4 $1.40
17 46637699349 support f headlight BUY 1 $305.45
19 46627684546 fillister head screw (M5X18) BUY 2 $1.93
20 46637694399 slipstream deflector (LEFT) BUY 1 $27.80
20 46637694400 slipstream deflector (RIGHT) BUY 1 $27.80
21 06327657966 fillister head screw (M5X20SI) BUY 4 $0.72
22 46612308594 flat washer BUY 4 $0.78
23 46637664846 bush (6,9X2,3) BUY 4 $1.87
24 07119906348 o-ring (6X1,8) BUY 2 $0.50
Nope that doesn't help, as it lists part 7 as cap nut chrome.........the bike doesn't use a cap nut.....it uses a threaded bush....I need the threaded bush part number.
Andy
On the diagram you need part 4 number 46637676996 ,the dome head goes on after and bottoms out on the thread to stop the bush dropping off
Thankyou that man, I was getting very short with Motorworks on the phone today for sending me the wrong part out.
Thanks again
Andy
the part you need is no 11 .this is the internaly threaded bush with the two flat faces . you may also need the domed nuts if yours loosened and fell off .regards robert.
