Performance boost gadget
  • Thread starter Thread starter Bigtwin
if you let any engine be fooled into thinking it needs more fuel, you'll always get more power to a point.
I don't think this would do your engine any good in the long term, too much fuel can be as bad as to little IMHO.
cheers
If it really was that easy, then people like Dynojet and Techlusion would be out of business. I'm sure there are times when the engine is running on the lean side where the extra fuel will come in handy and no doubt 'feel' better, but most of the time the engine is fuelling correctly, which means this device would be over fuelling..not good! you know what they say, If it sounds too good to be true........!
the 1150 does not run closed loop throughout rev range, so that thing would only do anything at all low down.
if the CO probe is working properly then mixture should be optimal anyway. why would you want to richen the mixture?
my shitty stick will remain untouched by this device ;)
