petrol
  • Thread starter Thread starter hooker
hooker
after doing quite a few modifications to the gs 650 for my partner ie new sports can k&N filter bmw lower shock we went for a run but when we parked up she was getting petrol coming out of the overflow pipe for a few seconds and then it stopped,
when we rode home the same thing happened on drive way any checks or suggestions ,please
OK thanks,that's the breather from the roll over valve on the top of the tank under the seat.Not sure why that should leak unless the tank is overfilled which presumably it's not as you've been out for a run.As you have lowered the rear suspension the bike should sit more upright on the stand so that shouldn't be a problem.
Are you getting excess pressure in the tank,ie does it hiss when you undo the cap?
Tony
thanks tony i will check that today as she did fill her tank half way through ride...
cheers les....
