Photobucket help ...
Pipster
north west
When i use photobucket to post photos they are way to big how do i resize them smaller...:thumb2
Example below
There are plenty of free programs out there for resizing pictures. An easy to use one is available from Microsoft. Called Image Resizer it can be downloaded HERE (scroll down the right column).
After installing it right click on any picture in your album and select 'Resize Pictures'.
Select the Medium or Small option and click on OK. Your photo will be saved in the same folder (it will not over write the original).
Tuned are you saying resize as you upload from pc...Tryed to resize after i uploaded them to photo bucket and they still posted too big...:nenau
Thanks :bow
photobucket should resize to the size you picked in the options panel without the need to use another program.... i'll go try it to make 100% sure
Thanks Tuned you're spot on
Should have resized as i uploaded them ...
I uploaded them full size should have used 640x480 message board setting :thumb2
