Pinlock Problem
Buz
Forest of Dean
Had a mooch around the threads but cant find anything appropriate....sure someone will prove me wrong.....
Went for a run today and yep, pished it down, after a few miles i realise the wet is on the inside of the Visor :blast after trying to wipe it i discover the wet is between the Pinlock and the Visor! Onlt answer at the time was to remove the Pinlock.
What do I do now?
Is the Pinlock now knackered and do I have to replace it? Is there a way of cleaning it and re-fixing to the Visor? It's on a Aari Condor if tat makes any difference?
I've had the Pinlock and the Visor for about 14 Months and both have been looked after and can see no scratches.
Now this has happened i'm debating whether to purchase new ones and keep this as a spare if it can be put back together? :augie
Thing is I've found up until ow it has worked perfectly.
Thoughts and suggestions please......
Lot less than a visor so I would buy a new insert for approx £20
Try putting the insert back on and rotating the pinlock screws to see if you can get a better fit? Possibly one of the screws got knocked out of line a little allowing a gap between visor and insert?
Just fitted a pinlock yo my new tour x3 it didn't fit properly until I rotated the pinlocks.
hope this helps
