Please help - Flickering LED spotlight
FastestGSA
Lincoln
I have additional Touratech LED spot lights fitted to my 2014 GSA and one of them has now started to flicker when the ignition is off. If I unplug it then the other light starts to flicker. The bike has done a massive trip and has seen every kind of terrain and weather so it amazes me that this is the only problem. I'm stripping the bike down for general maintenance and general TLC and to solve this problem. I'm not an electrician but generally capable. I will give all the contacts and loom a good clean and check for bad connections, what else should I be looking for?
I had that problem on my gsa standard fogs/running lights. Turned out to be a poor connection. JJH
If they are both on the same earth point start by looking there first.
Assuming these go through a relay?? I would swap that out first.
if not are they wired directly through a switch to the battery???
If they were on the CANbus there should be no power after 30 seconds or so.
