robb Registered user Joined Oct 13, 2003 Messages 705 Reaction score 0 Location Temple Herdewyke, Warwickshire Apr 21, 2005 #1 Panic - how do you use the plastic thing in the toolkit to remove the plug wire?? Is it just pull off?? thanks in advance...Rob
simonm Active member UKGSer Subscriber Joined Jan 8, 2002 Messages 286 Reaction score 0 Location Sheffield Apr 21, 2005 #2 yep just pull off dont lose the placcy tool tho - its virtually imposible without it
robb Registered user Joined Oct 13, 2003 Messages 705 Reaction score 0 Location Temple Herdewyke, Warwickshire Apr 21, 2005 #3 thanks - glad I'm not changing the plugs it's miles down that hole
Steptoe Him/Bloke/Fella. UKGSer Subscriber Joined Oct 12, 2003 Messages 73,333 Reaction score 20,963 Location S/W London. Apr 21, 2005 #4 robb said: Panic - how do you use the plastic thing in the toolkit to remove the plug wire?? Is it just pull off?? thanks in advance...Rob Click to expand... Twin spark or single spark - they're different . The twin spark is easier with just a large flat screwdriver, if you've tried to use the one supplied in the toolkit you'll know what i'm talking about
robb Registered user Joined Oct 13, 2003 Messages 705 Reaction score 0 Location Temple Herdewyke, Warwickshire Apr 22, 2005 #5 Re: Re: plug wire removal Steptoe said: Twin spark or single spark - they're different . The twin spark is easier with just a large flat screwdriver, if you've tried to use the one supplied in the toolkit you'll know what i'm talking about Click to expand... twin spark - I loosened it with a screwdriver and the used the plastic thing. It wouldn't budge with just the plastic thing
