POI
jack930
Warminster, Wiltshire
Ive just got a TT Rider.for a trip to France and ive been at it all day and finding/plotting places on a map then trying to get some POI transferd from the My Drive to the device but its not having any of it,, is ther any other way of doing it without using the my drive.? even when i connect the tt to my pc it does not sync and im unable send the points to it,
If you're using MyDrive, I assume you have a TT 400?
I use http://www.myrouteapp.com/ to load routes etc. to my TT 400 , will connect via the usb cable. There is also a POI search facility to label your map / route.
I have no idea what tt it is as all it says on box is rider and model says 4GD00
I think that is the Rider V5 model, then you will need Tom Tom HOME (google it) and TYRE (http://www.tyretotravel.com/) is the planning tool I've used for years, it also pays to buy the Pro version.
Home will allow ongoing updates to the unit and if you have a lifetime maps, will keep you up with the latest map versions as well.
TYRE allows you to transfer planned routes to your Rider via a usb cable.
