oldrascal
This is not funny - I feel a complete twat as in the charming 16th century verse:
Here is the rub. I bought an Optimate 4 to keep the battery fully charged and to avoid being tempted out on icy and salty roads to do the same thing.
I used the Optimate lead's crocodile clips connected to the battery and the whole system works a treat. Now I want to follow the advice given on this board and hard-wire the waterproof cable/plug combo that comes in the kit to allow seat-on charging with the waterproof plug cable-tied to the bike.
So screwdriver in hand, I approached the job in a methodical way and realised that I had no idea at all what holds the positive battery terminal cover in place. All I can see is that it doesn't look like a screw.
My plan was to undo the positive terminal and keep the connector in contact manually whilst fitting the Optimate positive lead. Then do the same thing with the negative terminal. That should avoid having to reset anything I think. But if I can't undo the positive terminal, my cleverly thought-out plan falls apart.
So what's the way to do it?
They talk't of his having a Cardinalls Hat
They'd send him as soon an Old Nuns Twat
