Pretty but not not too scary
slumberjack
Tavistock PL19
Next May my wife and I want to do Poole - Cherbourg, St Narzaire - Gijon, through the Picos and then back home through the Pyrenees. As she does not want to subject her newly acquired GS 700 (currently back at the dealers with a sticking 3rd gear) to vertiginous ascents and descents could anybody suggest a pretty route through the Pyrenees, avoiding major roads but keeping off the dirt without the scary bits. Thanks
Do the N260, Brill roads, nice scenery, quiet, no gravel lol
I rode the length of the Pyrenees, west to east, by dimply following the made roads that run along the top.
None of it is off-road and nothing that I would not ride on any motorbike or drive any car along, rain or baking sun. Yes, you will come across some parts that are less well made than others, an you'll find cows in the road, but that's mountains for you.
She (and you) will be fine, I promise.
I dimply followed some roads the other day, and it really fecked my suspension. :eek
Just wing it. The main roads are as good as here in the UK. Get a good map and stick to the bigger roads. You'll have a great time.
None of the roads I've ridden on in the Pyrenees, marked on a Michelin road map, were anything less than decent tarmac. The odd pothole but almost always better than country roads in this country.
There are some roads with scary drop-offs, but that's the up and down nature of mountains for you. :D
Robin is spot on right.
Arm yourself with a Michelin 1:200000 scale map. You should be able to see the red N routes, these are all the equivalent of our A roads and will be in just as good condition. These will be useful to get you from A to B in complete comfort and quickly. They are also useful to link you up with assorted lesser and more interesting roads.
There will then be a whole bunch of yellow D roads. In the main these are the equivalent of our B roads. All will be solid and certainly rideable on a pushbike, motorbike (of any sort) and driveable in a car. These will wiggle about, probably up, over and between the passes, with hairpins - with inevitably a drop over the barrier to the valley below (it wouldn't be a mountain otherwise) - for sure and may not be 100% smooth, but that is why you are going to the mountains in the first place. Ride and enjoy them in complete confidence.
You will also see white roads. These will either be roads that fill in the gaps between the N and D roads or roads that run up to higher view points or ski villages. You will see that many are the same width as the the D roads, so dual track. Others are half the width. They will be just as you imagine, maybe in quite good condition maybe not. All will be rideable, just be careful as always.
You will then see some white roads with a broken border. These are probably unmade roads and sometimes tracks. Avoid them or try them..... I think you should miss them out.
What would I do? I would take the yellow D roads. Then, if I came to a white road with an unbroken border I would take a look at it and give it a go if my companion fancied it. If they didn't I would miss it out to make their day happier. Within a day or two you will get the hang of what the roads are like, what roads you haven't yet ridden (but can see on the map with all their squiggles and colours) are probably like and plan your next day's riding accordingly. It's the great thing about having a decent map, it tells you lots. The other thing you'll learn is how long it takes the pair of you to go from A to B to C to D. If bods make one common mistake, it's usually underestimating the distance and time taken.
The big trick is not to hype the whole thing up, making your companion fear the worse before they have set off. Most riders (and definitely their bikes, without a doubt) are much more capable than they think. If they are really uncomfortable, wet, cold, scared or just out of sorts for whatever reason then find the simplest, fastest route out.
You and she will have a great time, I promise.
Doing the pyrenees East to West 5-15 Spet 2013 can't wait.:clap
Ferry is already booked Hull-Zeebrugge. £380 for 4bikes and a 4 berth cabin return....Bargain.
Steve.
Steve.
People's is extra! :P
Just done the hull-zeebrugge mini cruse with the old boot, bargain little break!
sound good. have done Cherbourg and the surrounding area. my advise is take more money than you think you'll need as it can get a little pricy by French standards (over a 2Euros for bread in some places) oh and take a phrase book if you not fluent as in the smaller towns there is NO ENGLISH !
yep !! french roads are the best in the world as far as im aware. . . smooth and no pot holes (so perfect for the biker) and wioth the toll system they use means they are always empty too. anyone know a better country for the biker ??? let me know
