Problems fitting WP 4014 FUSION Suspension
Dave & Val
Plymouth, Sunny Devon
Has anyone else had problems fitting WP 4014 FUSION Suspension to a standard R1150GS, Mine is a 03.
Got the front sorted,
Then trying to fit the rear could not get the thing to fit up by the air collector box. The nipple and steel flex for the reservoir is coming of the unit at 90 degrees to the vertical, which is stopping it being pushed up to meet the mounting for the top of the thing.
Any easy solutions, can the air collector box be cut? (I don’t know what it does apart from collect air for some reason)……..
Looking like I’ll have to take it to JD Racing at Saltash to see if they can move the flex down. This could lose all the pressure in the reservoir which would cost to refil.
Anyone had, and solved this problem?
Dave & Val
Turn it the other way around so the flex is at the bottom?
Don't really know Dave, just a thought :)
