Problems opening a MSDOS file in Windows XP
Marjorie Proops
This is driving me bonkers!
I've received what is basically an MSDOS file via email to my PC running on XP.
The file arrived as a zipped file and, following the instructions from the author, I chose 'save file to disk', changed the name to 'PROP.EXE', sent it to desktop, chose 'open full screen' and 'close on exit' in the options menu - all as instructed.
The file logo appears on my desktop, but when I try to open it I just get a black screen for a couple of seconds then the screen just reverts to the normal start menu - any ideas :nenau
(It's a boat propeller calculation program).
Thanks,
Steve
Copy the file to your "My Documents"
Select Start/Run and where it says "Open" type in
CMD
and click ok
You should get a Command Prompt window and by default be in your profile base folder.
Type
CD "My Documents"
and Enter
then try running
PROP.EXE
then Enter
What happens?
