The title says it all really - having just updated the maps on my Zumo when I load routes that were fine before rather than following the roads I now have a list of way points that on the map view screen are joined together by straight lines. Looks a little wierd and whilst not a major problem as I can follow the rough direction I was just wondering if anyone else has had the same issue and if so what was the fix.
Simon E
Simon E
Doh... Just planned an Alps tour for June/July, new Mapping is on the way from Garmin (ordered DVD rather than download, long story). Moving from 2008 to 2011 mapping, looks like I'll have to check all the via points carefully in the new mapping.
- sorted by copying onto P/C re-calculating, deleting original from Garmin and then sending re-calculated version back to Garmin. Have to say it seems a really arse about face way of doing things as both Garmin and P/C should have same map sets. Will be a real pain if I have to do that every time Garmin release a new mapset
