Hi Gang,
Does anybody know where I can get the metal bracket that holds a PTT switch to the handlebar from, I want to make up a PTT switch for my small PMR radio so I can use it on the bike
Like this bit - View attachment 81826 just the metal bit.
thanks
Cheers Roddy, I did think of using a 'momentary on' toggle switch at one time but thought a m/switch with an operating arm like the one below would make for nice easy operation, just touch it sideways with the index finger, but so far I haven't found a waterproof version (to be truthfully, I haven't looked that hard yet )Ebbo,
That a neat solution, but I've wee hands so it may not work for me.
what you maybe looking for is this
http://www.maplin.co.uk/module.aspx?ITAG=SPEC&ModuleNo=2341&doy=16m1#spec
toggle type C - this gives a momentary ON, OFF, permenant ON
which is the type that in my first post, you can also get waterproof covers for these switches, and a type of heat shrink that is coated with 'glue' on the inside so when you heat it up to seal it is effectively waterproof the connections
I need to have another look at this as I was thinking about putting the metal part I looking for round the grip but that may interfere with the heat function of the grip, I need to check that
cheers
Sorry Roddy, I wish it were that simple, the PTT cable splits to two 5 pin DIN plugs, one side goes to the radio, the other to the Autocom. I've tried to get one of the plugs apart but it seems to be potted in some kind of plastic, if I go on much longer it will be wrecked (it pretty much is now, they cost around £38 ) just belling them out doesn't alway give you the answer you need, there could be resistors and/or capacitors hiding in there...On the PTT page of your site did you happen to meter out the wiring from the PTT switch to the Autocomm connector, as what pin the red/blue screen wires went to ?
cheers
Thats very kind Mark because mine's totaled now, I never did find where the blue wire went, but it didn't seem to bell out properly.Got one for you.
Pm me your address and i will get it in the post friday/saturday.
