QPAC - Quest Power & Audio cable
RAM-man
depleted member !
Wes' Lundernshire
Posted today on GPS Warehouse web site (www.gpsw.co.uk)
QPAC - Quest Power and Audio cable for Motorcycles
QPAC is designed for use by motorcyclists in order to power a Garmin Quest GPS unit using the RAM mount and RAM GA15 cradle system.
Its easy to install and looks neat and tidy when fitted. QPAC offers a unique mount location as its 'sandwiched' between the RAM cradle and diamond base to form part of the mount itself.
QPAC versions
QPAC01-25 Bare wire end power cable with in-line 1.5 amp splash proof
fuseholder, 1.8m cable length, Quest connector and female 2.5mm jack socket.
QPAC01-35 Bare wire end power cable with in-line 1.5 amp splash proof
fuseholder, 1.8m cable length, Quest connector and female 3.5mm jack socket.
QPAC02-25 Power cable with BMW type DC plug and 1.5 amp fuse, 0.5m cable length for dashboard power socket, Quest connector and female 2.5mm jack socket.
QPAC02-35 Power cable with BMW type DC plug and 1.5 amp fuse, 0.5m cable length for dashboard power socket, Quest connector and female 3.5mm jack socket.
QPAC03-25 Power cable with BMW type DC plug and 1.5 amp fuse, 1.7m cable length for a power socket located under the tank or near the rider, Quest connector and female 2.5mm female jack socket.
QPAC03-35 Power cable with BMW type DC plug and 1.5 amp fuse, 1.7m cable length for a power socket located under the tank or near the rider, Quest connector and female 3.5mm female jack socket.
prod2733.html
prod2735.html
You can pre-order and its first come - first served.
RAM-man
