Query from possible purchaser
I agree that the side stand is a tad too long, and that’s a good idea about raising the front.
:thumb
If you go on the rs forum you will see some have shortened side stand. I have done the same by 10mm makes a big difference when on uneven ground
Of course another factor to bear in mind is the Spring rate of the suspension. I think that it is probable that ESA bikes and Standard bikes
will have the same rate springs.
The only difference then will be how the damping (would that be compression or rebound- at both ends), is adjusted.
Confusing , definitely!
