I seem to have lost two data fields. Should have 4 now (after playing) only got 2. How do I get the other data fields back? There's 2 in the bottom rhs but the 2 top rhs have gone!!
Menu - edit fields - you can then select the white box you want to edit by moving up or down with the central button once on the correct box press ok then move up or down to select the fields you want.
But there's only 2 fields there, which is my problem. There use to be 4 before I started messing around. In fact, there's probably 3, the bottom 2, but the top 2 are "merged" into 1 and don't display anything.
If you ever get too bothered by the smaller screen size, try leaving the turn pointer on whilst turning off the data fields. I think Fanum is the chap to thank for that tip and it certainly works
