QUEST POWER LEAD
I bought one too, needed it before ram-mans ram-cables were available, on a 50 mile bumpy test ride it was fine, fits on my ram bracketry and 'does what it says on the tin!' I decided I needed onboard power to it after speaking to Garmin tech support when my quest battery started to run out of go after 8 hours, garmin said if you use the backlight the battery can last as little as 6-8 hours, the 'up to 20' quoted is for no backlight usage........
