Quest rear connector (power & Audio)
  • Thread starter Thread starter FIN_GSer
FIN_GSer
Hi
I did search on Google & this site for Quest rear connector. No luck.
I would be happy if someone explained what is the meaning of 6 golden connector pins at the back of the device.
There is power & audio in these pins but which is which?
FIN_GSer
FIN-GSer .. the simple answer is do search for QPAC in the Forum. Its a Quest Power & audio cable (several versions available) that is used with the RAM GA15 cradle.
If you want audio output only (eg no power option) then look at ACQ-25 or ACQ-35 and again, it attaches onto the RAM GA15 cradle.
Source for these is GPS Warehouse (www.gpsw.co.uk) and not RAM-man.
The connector panel on the rear of the Quest has 6 pins of which 4 are used (eg power and audio) the last are believed to be for a serial connection point.
RAM-man
Thanx RAM-man
I have read lots of QPAC related threads lately.
I am after "power only", no audio cable.
Well, I can allways tear my current adapter into pieces and find the information myself. Somehow I thought someone had done that allready :confused:
FIN-GSer
>> if you leave audio out, then another GSer wants it in, that's the problem; when you get choices.
Well, I can allways tear my current adapter into pieces and find the information myself. Somehow I thought someone had done that already
>> been here before; inside there's a Vreg and .. its a lower temp rated than the Bike version, and .. its not sealed or waterproof, and .. not intended for bike use, and so on ~ BUT ~ since when has this stopped anyone until they blow it up.
RAM-man
RAM-man
Fair point, but if you can get an audio only cable, why not a power only cable ?
...... just order a QPAC from gpsw and ask them to clip the audio plug off before posting ......
Turn voice off on the GPSR
Or ofcourse you could buy the cable that does both, and TURN OFF the voice prompts from the GPSR ????? Job done ! :cool:
