Question ?????
Dave GS
Dave here, from across the pond. What is everyone using for foot pegs? Mine are stock r1200 gs but would like a bit more width. Are there replacements that will fit without modification? I do a lot of gravel riding in the standing position and it would make more sense to have wider pegs. :beerjug:
Get some FastWay footpegs, you might have to get some extra shims to get them level but they are the dogs.
Be careful in choosing the wider pegs. If the pegs are wider on both sides (front and rear) it will mean that the gear change lever is too close to the peg and then of course more expense buying a longer gear lever. I believe touretech have a wider peg and is wider on the rear only. Good luck Roger
