Quill T3 update
  • Thread starter Thread starter tallman
tallman
Over a month since installation without lambda sensor. Fuel consumption DOWN (three tanks to make sure), power (unmeasured) noticeably improved, bike generally feels less strangled. If the sensor removal meant that the ECU would default to a higher consumption, I can't see it. Backfiring now minimal.
Motronic has not been reset, any thoughts (other than if it ain't broke, don't fix it)?
when you say down do you mean it uses less or more fuel, mine used more fuel when I did it so I put ity back and it cam,e back toi normal, 45 ish on a corrected speedo with no noticable difference in performance compared to without the O2 sensor.
No cat and Sebring can.
Similar threads
Replies
3
Views
1,320
tallman
