B Murr
Decided to install a fusebox to power sat nav and spotlights. I wanted it to be on a relay activated by ignition power. First fusebox I bought was a regular spade type and I couldn't find a suitable home for it. I bought a mini spade version that can power 4 outlets which is plenty for me and its home can be seen in the photo. So I have one relay activated power source going into the box, I've soldered a wire across the 4 inlets so that each fuse receives power. The fuse box costs £10.70, http://www.ebay.co.uk/itm/4-Way-MINI-Blade-Fuse-Box-Holder-12v-amp-24v-Universal-/292195721641?. There was a tank clearance issue with the outboard mounting part of base but I cut that off and I think one nut will suffice for holding this board on, I can always use double sided tape if it starts to move at some point. I already had the relay as it came with the spots.
