I of the Strom
The left hand head gasket on my nearly 94K miles bike went and when the head was taken off the lobes and buckets were found to be badly worn. There was no discernable noise and without the gasket blowing I'd not have known about the damage (at this time). Is this typical wear for a bike that's done this sort of milage ? And, is this wear an indication that more specific problems and wear are inevitable elsewhere in the engine ? Also, the LH cam chain tensioner is still the original spring type, making no noise nor showing wear so, do these really need to be replaced by more recent designs ? When I bought the bike I was told it had been laid up for a while but turned over regularly (perhaps not !) could this be the cause rather than the milage done ?
, I fitted the upgraded tensioner to my bike a couple of years ago after being frightened by the nasty noises on startup.
