R1150 GS: What can I expect to start going wrong, and when?
retroman
Cardiff ex-pat now escaped to Penzance
... this thread is not as pessimistic as the title might suggest.
My standard R1150GS is 2 1/2 years old with 28k on. I use it vitually daily. Apart from surface corrosion on the fork brace and lower fork legs I can't fault it. It's all the bike I want and does everything I chuck at it.
Lots of people on this forum seem to change their bikes regularly and good luck to them, but I intend to keep mine long term. So with that in mind, are there any weaknesses that manifest themselves at around about certainn mileages - engine, drivetrain etc .... what's the average life of a clutch, for instance?
I now a lot of this depends on riding style etc, I suppose I am a 'cautious' rider in that case ... but I do maintain the service intervals religiously at a BMW dealership.
Any thoughts?
:confused:
That would depend if you plan to hit a wall again;)
but I rekon 29k is when trouble will start:D
A annual run has its advantages:dabone
Cam chain.......schedule says replace at 34k, group wisdom seems to say do it earlier, like soonish on yours ;)
About to change my front fork seals at 20K.
How normal is that?
Could it be that I ate all the pies?
WTF ? :confused:
2003 1150 GS `adventure`, currently 77000KM around the world now in Argentina 40000km to go on the way to Montreal...
anyhow not sure if i have a good un or or bad un, list of carnage is as follows...
1, bevel box input oil seal
2, gearbox output oil seal x 2
3, final drive output oil seal
4, replaced paralever bearings, after endless adjustments
5, collapsed final drive output bearing
6, fuel pump
7, rear brake lamp bulbs x 4
8, instrument bulbs x2
that`s all for now folks
Fanum said:
Look, if you want to be awkward, you can change the poly V belt instead ok???
:rolleyes: :rolleyes:
Glad that was cleared up, I got seriously confused also ... just to be pedantic, schedule says replace at 36k.
Of course, I could use Ming's technique of replacing everything on the bike under warranty .... 'my gearbox failed whilst sitting in the garage ....'
:duck:
:duck:
And don't forget to try and get a new fuel tank 'cos this one just got all bent up around the pump hatch an' it wasn't me guv!!!!
:hide
So when was this gearbox fitted Dave????
oh and bill you had any flood damage recently?:eek: :eek:
