R1150GS Alternator Belt Snapped
RW1102
REDCAR
Hi Guys,
Having a lovely day out with the Scarborough, Whitby and Pickering area today, when the battery light came on started to cut out.
Got the bike onto a trailer and home, just looked now and the alternator belt has slit down the center and came off the pully's, no extra broken bits in the bottom just a little bit of belt.
I've looked at a few threads on here and they have mentioned damaged censors?
so the questions and thoughts are:
is there anything else I need to be checking before I replace the belt
what damage should i be looking for
is this a normal occurrence (belt changed 6000miles ago, 48,000 now on her)
thoughts and comments much appreciated
Rob
Damage is often when you use a screwdriver to tension the new belt the point you want to jamb it in is where the H.E.S cable is:blast
I'll keep that one in mind when I fit the replacement:thumb2
" thoughts and comments much appreciated "
Buy 2 replacements,keep spare on bike ;)
I always do.....................
Thanks Ash,
That's my intention, once bitten
It also makes fitted one never fail....Murphy's law but in a good way:D
