r1150gs clutch hose swop
cbrgaz
Cumbria, england
Does anyone have any tips for swopping the clutch hose on an r1150gs?
My current one is suffering for the usual rotten swage fitting.
Just fitted to mine during clutch & slave cylinder replacement.
Clutch hose linky
Bleed hose linky
Choose stainless end fittings and sleeving colour to suit your preferred aesthetics. Top quality and cheaper than the alternative, which is the S/S clutch line from an R1150GS Adv.
:thumby:
Clutch hose linky
Bleed hose linky
:thumby:
I believe these links are not quite right:
Clutch hose:
http://www.probrake.de/Stahlflex-Kupplungs-Leitung-fuer-BMW-R-1150-GS-2002-ABS-II
Bleed hose:
http://www.probrake.de/Stahlflex-Kupplungs-Entluefter-Leitung-fuer-BMW-R-1150-GS-2002-ABS-II
The bleed hose is much shorter but is 10 euro's more expensive
KP
+1 for probrake, found them good to deal with when I replaced my clutch hose and slave cylinder last year, although also thought cost of bleed hose was high compared to clutch hose! Decided best to cover all bases and replace the lot though. A long (10") Allen key is very useful for undoing slave cylinder.
Well i swopped over the clutch hose last night.
Quite a mission, especially as i decided to leave the shock in place!
I have replace the clutch hose with a GSA one, but left the bleed hose as is, although i did cut back the rubber swage cover to hopefully prevent it from suffering the same as the clutch hose.
