metallic_lt
Hello People!
I adjusted throttle body STOP screw
( fortunately, did NOT touch TPS screws ) and now playing with it at the moment.
I read TPS reading should be 370mV and most sources advise to measure with engine OFF. But some say to set it to 370mV WITH engine IDLING.
I am reading TPS from pins 1 and 4.
Question: Should engine be IDLING or NOT?
Some TPS reading:
1. Engine is cold ( standing overnight ) TPS reading 394mV ( Engine off after 1min idling TPS = 384mV, Engine off after 2min idling TPS = 380mV and engine temperature 1 bar )
2. Cold engine idling TPS reading 362mV
3. Hot engine idling TPS = 366mV ( 5 bar Temp )
4. Hot engine OFF TPS = 393mV ( 5 bar Temp )
COLD / HOT engine did not make much difference in TPS reading.
BUT .... Should I set TPS to 370mV with engine IDLING of OFF?
Thank You !
( fortunately, did NOT touch TPS screws ) and now playing with it at the moment.I read TPS reading should be 370mV and most sources advise to measure with engine OFF. But some say to set it to 370mV WITH engine IDLING.
Some TPS reading:
Thank You !
