gfspencer
Hope I’m not repeating something here –
I have an R1200GS and the special BMW battery charger.
The battery charger worked fine before the firmware “upgrades” that crapped up the GPS and the battery charger. Firmware upgrade V.7 fixed the GPS problems but it did not solve my battery problems. (The battery would charge – sometimes – but when it reached a full charge it would shut down and would not maintain a trickle charge.)
Yesterday I got a BMW “Adapter Lead”. Basically it’s a wire with two alligator clips on one end and a BMW “cigarette lighter” plug on the other. Attach the alligator clips to the battery, plug your BMW charger into the “cigarette lighter” plug and plug the battery charger into the wall. Now everything works fine. The battery charges and maintains a trickle charge.
If you wanted to permanently attach this to your bike it would be easy to do. Just get rid of the alligator clips, add crimp terminals and attach them to your battery. I’m thinking about doing that to power my heated vest.
It costs about $29 US. The instruction sheet reads Part Number ECE 7 688 865. The box reads 71 60 7 690 235.
The battery charger worked fine before the firmware “upgrades” that crapped up the GPS and the battery charger. Firmware upgrade V.7 fixed the GPS problems but it did not solve my battery problems. (The battery would charge – sometimes – but when it reached a full charge it would shut down and would not maintain a trickle charge.)Yesterday I got a BMW “Adapter Lead”. Basically it’s a wire with two alligator clips on one end and a BMW “cigarette lighter” plug on the other. Attach the alligator clips to the battery, plug your BMW charger into the “cigarette lighter” plug and plug the battery charger into the wall. Now everything works fine. The battery charges and maintains a trickle charge.
I use a 'normal' optimate with no bother. Bike did not burst into flames or explode.
