BigyellowGS
A friend has just purchased a 1981 R65... But it has a "slight" issue..
The bike will run and tickover okay.. no nasty noises and the gearbox is actually nice enough.
BUT... If you rev it passed about 3K and let go of the trottle the revs seem to hold on... not dropping off again... A little bit of brake/clutch and you can force them back down... once they drop below about 2.8k revs.. they drop as per normal.
The bike is fitted with Bing CV carbs.
I have checked:
No cables are snagging anywhere and that the throttle butterflies are actually shutting when the throttle is released.
Checked for any air leaks between carb & engine and between the carb and air box.
Checked the Diaphrams... These appear to be brand new, as do the slides.
Now all I can think of is that the slides could be jamming as they drop back down? or when the last owner replaced the diaphrams he attached them wrongly and the slides are the wrong way round (is this possible - should the holes in the bottom of the slide be at the front or back?)?
Any ideas on things to check would be great... As I intend to spend some time in the workshop tonight, stirpping and checking as much as possible.
Cheers!
I have checked:
Cheers!
