Rear brake light switch - help!
Kirst
A posh bit of Birkenhead, right on the edge of scu
Hi all
Well, my Dakar's just passed its first ever MOT, but with the condition I sort out the rear light . It's ON and won't go off. On all my previous bikes the rear switch was adjustable, just peel back the gaiter, clean the contacts, adjust height as preferred. This bike has a switch the likes of which I've never seen before.
I've looked in the manual (well. on the disc containing the manual!) and there is only a piccy and instructions on how to replace it.
Any help gratefully received please. :confused:
Kirst (skint and not wanting to spend any more cash getting through the Liverpool tunnel when I can use the bike for free)
I've checked the whole techy questions section here and couldn't find owt, so I've just found the Chaingang website and printed off 9 PAGES (!!!) of stuff about the rear brake light switch :clap (full 9 pages only because it wouldn't just print the bits I needed!)
I'll give it a bit of a poking-at later after I've stripped the wallpaper off Henry's hall walls. :help God, I hate decorating!
Any info still gratefully received, though!
Ta
Yours covered in minging old wallpaper paste and bits of paper
Kirst
Hi, the rear brake light switch on my 2000 Dakar sticks in the 'off' position.
It's a silly little micro swich inboard of the lever and it get 'shitted up' (technical term) especially when you off road a little as I do. I give mine a spray before each MOT to make sure it comes on when the pedal is depressed.
It's difficult cos you can't see it but give it a blast with WD 40 or similar, reach 'round the inside of the frame (by the front spoket cover) and work the switch with your fingers a few times,its like a thin strip of spring steel and you'll hear it click as it switches.
Hope this helps, works for me.
Thanks, Onepot! Tarka came round and gave it a coat of looking-at. The rear bulb had blown one filament, luckily I had a spare bulb, and he WD40'd the switch, then hey presto it works again. Yay! :thumb
So a big thanks to TARKA - ta, mate, a bottle of something yummy will be in your palms tonight! :beerjug:
