I had an intermittent LAMPR problem, which was quite rare until the day before my Scotland trip when it would not go away.
Turns out the clip the rear brake light clips into was broken, the bulb would not stay in contact with its power.
I had to directly solder to the bulb, as I was off to Scotland next day. I need to replace the unit, as also the bottom bracket is broken. Causing quite a bit of number plate vibration.
Question is can I buy just the bit circled on its own?
Already answering my own question, but guessing later LED light unit does not fit a 2006 GS?
