Rear shock absorber.
kenny8660
Forfar Scotland
2015 1200 GS LC 2300 MLS The rear shock absorber seems to have a lot of rotational movement! About a inch of movement, is this normal, (not a worn bearing problem) TIA Kenny.
There some rotational movement in the shock. i think mine moves a similar amount, and the mounts are absolutely fine. So long as it's not loose (eg the bolts are tight, and mountings are tight) i'd not worry about it.
