Recommend free flow air filter 1995 1100 gs
Ccmp
Member
Cork ireland
Hi, I'm installing a John gemi chip. I already have the bike decatted. What air filter would you recommend?
Yep, the original paper filter if you want the bike to last.
K&N gives you a couple of additional horsepower and less frequent maintenance, but K&N and similars let in too much fine dirt and wear out your pistons/rings/bores. Mate of mine had his Honda engine requiring overhaul (low compression) around 60K when switched to K&N.
The solution would be to use an oiled pre-filter put on the intake tube, but then you'll lose the benefit of those couple of horsepower K&N would give.
A dynoed R1100R, 2-3 HP more vs stock paper filter. The R1100GS has pretty much the same air filter setup.
Have you a before and after graph ? BMW would be very interested in such a percentage gain for so little effort. The inlet tube and airbox offers more restriction than the air filter.
I know this will seem as heresy to some but HT were clear, a standard air filter changed at same time as oil filter will be far better for your engine than a K&N which is either not oiled at all or as is usually the case, over oiled.
Sent from my SM-G925F using Tapatalk
We all know the "inlet tube" is a cutting edge Ram Air orifice designed to over-pressure the airbox and yield lots of extra ooomph.
KN filters and there ilk are one of my pet hates.:mad::mad:
Next is KN filters sitting in an engine bay with no ducting or heat shields to get cold air into it. :mad:
They do not look cool!!
The only way you can get more air into an engine with an air filter is a filter with bigger holes and bigger holes means bigger dirt gets through.
It ain't rocket science unless its on a rocket.
Adrian
